跳转到主内容
加入维修社区 - 创建账户
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
Bootable USB is not recognized after using Transmac
Hi ! i recently formated my Mac book pro 13inch 2012 model and plan to reinstall os x high serria with the help of usb bootable drive , for creating mac os high serria bootable usb drive, I used windows pc to create bootable drive with the help of Transmac ,in that , i done format disk for Mac and restored the disk image by choosen Mac os x high serria )DMG file . After completed Restored i Ejected usb and PLUGGED in to my Macbook and power on by holding option Key ,but USB was not recognized not showing in startup drive .
PLEASE HELP ME WHAT I HAVE TO DO
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Did you press the Option key to get to the Startup Manager?
Mac startup key combinations
这个答案有帮助吗?
得分 2
2条评论:
Yes done by holding option key but it's not showing usb drive
完成的
@Rajukumar Reddy - I would suspect the drive was not fully setup. You do need to format the drive with GUID journaled file system (HFS+) and then copy the OS installer to the drive and then convert it to a bootable file.
How to create a bootable macOS High Sierra installer drive
And if you don't have it here the updated Installer file How to upgrade to macOS High Sierra Jump down to Step 4, make sure you click on the Blue URL labeled Get macOS High Sierra to get the installer file, you'll need to unpack it before you install it to the drive.
Here's more on why you need this file Vs any older ones If you've got an old macOS install image, it will probably stop working today
完成的
添加一条评论
I have been through the same procedure and now I am sitting with 2 damaged USBs. I think this is a bug, it doesn't work at all for me.
这个答案有帮助吗?
得分 0
2条评论:
yes, it is a bug. I destroyed two USBs don't use trans mac save your time and money.
完成的
Wish I'd read the reviews first. What's the point of a pay to use software if it doesn't serve it's purpose?
完成的
添加一条评论
So i downloaded the sierra.dmg file from apple's website. https://support.apple.com/en-us/HT211683
After that, I have no idea what to do. Inside that dmg file is a InstallOS.pkg, which, if i use belana etcher or transmac simply formats the flash drive appropriately and then copies the InstallOS.pkg to the drive and nothing else.
I have an M1 mac mini and I am unable to download a sierra install to create install media for a older Intel Based MBP.
I was able to download a ventura installer and use the terminal to create a bootable usb. So that worked great. But i need sierra or something older.
Can anyone point me in a direction to unpack this .pkg file via windows or an m1 mac?
这个答案有帮助吗?
得分 0
2条评论:
@spicyramentt - First your M1 system can’t use Sierra! Next, TransMac only works on Windows PCs and I haven’t been able get it to create a workable format for a Mac boot disk if that is what you are trying to do.
So what is the goal here? What is the system you are trying install a older macOS onto?
完成的
@Dan have you come up with any solutions for creating bootable macos on a pc?
完成的
添加一条评论
添加你的答案
Rajukumar Reddy 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 31
过去 30 天: 104
总计 12,501
