跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Screen doesn‘t work after replacement
So i dropped my iPhone 8 and when it fell the display didn‘t function anymore altough the glass was intact. At first when I used the power button the screen did turn on and off (just like a tv without any channel on; you could see that it has elecricity but it was a black screen tho). After i made a hard shut down (pressing the keys) the screen was just plain black (no electricity) but everything functioned (except you know… the screen). I thought maybe the LCD or touch might be broken and bought a replacement screen. Long story short end, nothing changed after replacing the screen
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It sounds like you have damaged the backlight circuit on the logic board. You can check this by shinning a torch on the screen and see if you have an image. The backlight circuit will have to be repaired by a competent technician as microsoldering will be required.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Cem S 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 51
