跳转到主内容
加入维修社区 - 创建账户
任天堂于2019年9月20日发布了在Switch系列中更加实惠、且更纯粹的掌上游戏机——Nintendo Switch Lite,它有着一体式的手柄设计以及更小的屏幕。
Right bumper is stuck in a pressed position.
The right bumper button, not the trigger - the one above it, is stuck in the pressed position.
  • It doesn’t seem to cause any reaction in the game, so I’m not sure if the contacts are being touched.
  • Bumper doesn’t rebound when pressed, so maybe that mechanism has slipped away or ???
What’s the right way to fix that? Replace the button? Throw this thing I didn’t want my kids to have against the front window of the grandparents that bought it for them?
Cheers.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
5个答案
最有帮助的答案
I found this fix on youtube, it sounds funny but has actually worked for multiple consoles.
“I fixed mine and it’s been stuck for a month. I basically did CPR on it. I blew along the edges and awkwardly put the entire L button in my mouth then did one big blow. Then inhaled after and it popped back up.”
I know it sounds ridiculous, but this technique worked on my switch lite after the R button had been stuck for months.
这个答案有帮助吗?
得分 8
11条评论:
It's not ridiculous at all. It's like using a toilet plunger to pull dents out of a car. Depending on the type and severity of the dent it works. Occam's razor right? Sometimes the simplest (and even silly seeming) solutions are in fact the solutions.
完成的
Thank you so much i looked this up and i found this i tryed it and it worked thank you so much i wish you a beautiful life
完成的
Wow tysm it actually worked
完成的
thank you so much i thought o would have to buy a new one
完成的
wow this is hilarious it actually worked!!! 🤣
完成的
显示更多的6条评论
添加一条评论
Sounds like it already got thrown. :) Either it’s jammed (gunk, whatever) in which case “unstuck” it. Or the plastic button itself is broken, replace. Or the button module is broken, re-solder or replace. Or the the pcb around the button module is broken, dead. The shoulder buttons on the switch cons are poorly, cheaply designed. Good luck.
这个答案有帮助吗?
得分 2
添加一条评论
Could be that the spring is stuck/snapped. Should just take the back off and remove the trigger assembly, then see if the spring is there/moving.
这个答案有帮助吗?
得分 0
添加一条评论
Try getting canned air and spray some in the Gap between the it and the device.
这个答案有帮助吗?
得分 0
添加一条评论
You might just have to get new controllers because even if you try it fix it it will get worse so might be better to get new controllers.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
GB Lott 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 43
过去 30 天: 180
总计 17,462
