跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
Problem with FL2400/C2400 in iPhone SE
Hi everybody,
This is my first question right here. I’ve been looking for an answer to my problem but couldn't find it.
I have two Iphone SE (one is mine and the other is my cousins). My phone didn’t turn on after a screen changing. My cousins phone worked but the battery didn’t charge at all.
I could open them and see them under the microscope. Both of them had the FL2400 removed. I tried to solder them back but didn’t succeed and lost them.
So i shortened the pads of the FL2400 with a wire. Doing so, in my cousins phone i lost the C2400 cap.
So the result is this:
  • My Phone: FL2400 pads shortened with a wire and C2400 soldered. My phone doesn’t turn on and Itunes doesn’t recognize it. But i measured the current and is around 100-200mA.
  • My cousins phone: FL2400 pads shortened with a wire and C2400 not soldered. That phone doesn’t turn the screen on, but it is alive because Itunes recognize it.
So the question is, do i need to solder FL2400 and C2400 and may be the phones will work? or the problem could be elsewhere.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Fl2400 will need to be in place the cap doesn’t really matter, did both phones have the battery disconnected when you connected the lcds
这个答案有帮助吗?
得分 1
7条评论:
Yes both of them had the battery disconnected. I also checked the backlight filters of the display circuit and are OK.
So i should try replacing the filter then.
I have to see where to buy them because in my country (Argentina) i won’t find them.
Thanks a lot!
完成的
Is that possible that not having the FL2400 can impact on no display at all?
完成的
No it would usually only cause a battery percentage issue.
完成的
Do you think of any other test that i can do to troubleshoot this?
完成的
Can you buy zxw. It will give you diode readings for the lcd connector.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Juan Pablo Iñigo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 515
