"The network channel assigned to your Wi-Fi network is not supported."
Bought this printer second hand, and it didn’t come with any installation CD. I installed the drivers/utilities/etc available on the Epson website, but when I try to connect my printer to Wi-Fi, I get this message. If I try to manually input my SSID, it doesn’t work. When I try to connect via direct USB cable, I can install successfully, but the printer status says “drivers not available”. I’ve been working on this for the last hour and I’m super frustrated, so any advice would help.
What is your system a PC or a Mac? Also what is the make, model and OS release you are using.
由 Dan 完成的
If it is a wifi issue, perhaps it is not compatible with the frequency of your network. I've had devices that are not compatible with 2.4 or 5 GHZ networks. I had to enable it in the settings to get it to work.
由 FiftyFixes 完成的
