跳转到主内容
Xbox One 手柄在2016年随着 Xbox One S 的推出而问世,并增加了对 Windows 10/11 的蓝牙支持。 该手柄修复了 Model 1537/1697 手柄上的许多设计缺陷,更加可靠。该手柄已被改进版 Model 1914 手柄所取代。
163 个问题 查看全部
View button not responsive
I have a camo 1708 controller with a view button that does not work. Tested via the Accessories app, updated the firmware, plugged it into the console. All the button work except for the view button. What do I need to replace?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Actually, you might fix it by cleaning it if you are lucky. Otherwise, I would try to change the conductive pad. Here is a video where I had a similar problem and that cleaning worked really well : https://youtu.be/yilEo_n_364
这个答案有帮助吗?
得分 1
1条评论:
Had the same issue on a brand new controller that i was too lazy to send back.
I fixed it today by just cleaning the pad with a good squeeze. (It was all good all clean but after putting my thumb in and scratch it a little it works nice, dunno why but it's fixed now)
完成的
添加一条评论
添加你的答案
jamincash 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 112
