How can I repair a broken handle on a hole hawg?
How can I repair my hole hawg broken handle. Those parts are no longer available.
The handles appear to be available on ebay for $12.99 stateside. (e.g. https://www.ebay.com/i/182289228254 )
Failing that, depending on what it is made of and how it’s broken you could:
Personally, I’d 3D print one - with careful design and suitable orientation on the printer, even humble PLA, which is safe and easy to work with, can produce an item easily strong enough for this. Just don’t leave it in the sun ‘cos the stuff softens around 70ºC.
这个答案有帮助吗?
Or if it's the other handle that's broken, there's a replacement for the obsolete type - e.g. https://www.ereplacementparts.com/handle...
I would recommend you look if there are any "3d print" makers around where you live. Ask them to help you with modeling the broken part (take it to them so they can take measurements etc.) and then print it for you. I would also recommend you to choose anisoprint continuous fiber 3D printing in your case. It is very tough and reliable stuff.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 232
