跳转到主内容
Samsung's flagship tablet, released in March 2017. Identified by model number SM-T820.
TAB S6 Half of the screen with white lines
Sometimes all the screen work but with lower resolution and sometimes half of it get black-white lines as the picture and the other half looks good.
The touch screen is working good and I am sure this is not a SW or firmware thing.
What could be the reason? any advise would be helpful.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
How you fix it?
I have the same problem
完成的
I have the same problem did you fix this
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @juankpg ,
Given that it is intermittent it may be a loose display flex cable connection at either end, display or systemboard or perhaps it is an internal problem in the display itself. Worst case would be a problem on the systemboard.
As a DIY repair all you can do is to open the tablet and check the cable connections are secure and if they are is then to temporarily replace the screen and check what happens.
Here’s a video that shows how to replace the display assembly in your tablet.
Replacement screens are available online. Just search for Galaxy Tab S6 LCD screen to get results for suppliers of the part that suit you.
这个答案有帮助吗?
得分 2
1条评论:
I have the same problem did you fix it
完成的
添加一条评论
添加你的答案
Juan Carlos 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 25
总计 3,739
