跳转到主内容
Is this a screen problem, or a iGPU problem?
A couple months ago, I was using my MBP as normal, and it started doing this out of nowhere: https://imgur.com/a/W3QaJeu
I guess this is a screen issue, but I was wondering if it maybe was a problem with the iGPU or something. And I don’t know if it has anything to do, but my original charger died a couple weeks before this, and I started using a third-party charger, could that have caused my problem?
Anyways, in case that it is indeed the screen, if anyone has any tips for not so expensive screen replacements, I’m open to listen.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
添加一条评论
1个答案
Your system uses the graphics engine within the CPU chip (Intel HD Graphics 4000)
This appears to be a T-CON chip issue within the display assembly. You will need to check things to be sure.
Follow this guide to Step 6 MacBook Pro(13英寸,带有Retina显示屏,2013年末)显示屏组件更换 Then jump down to Step 11. Inspect the connector for corrosion.
In any case your charger could also be a factor! Knockoff chargers can do strange things to your system. Saving money in the long haul costs you more!
Here’s the needed Apple charger: Apple 60W MagSafe 2 Power Adapter (MacBook Pro with 13-inch Retina display)
Don't Replace Your MacBook Charger With a Cheap Knockoff
OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth
Lacking safety features, cheap MacBook chargers create big sparks
FAKE Magsafe MacBook Chargers on eBay - Watch before buying a Mac Charger
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mperez9914 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 51
