跳转到主内容
加入维修社区 - 创建账户
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
iPhone 6s doesn't turn on
After screen replacement phone doesn’t turn on and no response with itunes.
I only have a multimeter and I checked below.
Checked battery and got 3.45V
Checked PP_BATT_VCC and got ~120K ohm and keep increasing..
PP_VCC_MAIN: ~70K ohm
PP5V0_USB: ~1M ohm
Checked voltage PP_BATT_VCC, PP_VCC_MAIN with USB charging cable connected : 30-60mV.
Any clue?
I replaced my broken screen and I messed up with installing front camera cable assembly. I accidentally connected front camera cable to display connector and I felt something near the connector was getting hot.
I realized I did everything wrong and I started over and reassembled but the phone won’t turn on.
Any comment or help will be much appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You will have to diode all the connector pins and compare with a known good board or get some board view software that supplies diode readings. Remember to put red probe on ground while diode testing.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Shinwy71 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 41
