跳转到主内容
加入维修社区 - 创建账户
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
Ipad 4 Restore failure
I have ipad 4 which was working perfectly well until about 3-4 years ago when I opted to do the Apple recommended software update. And for some reason it failed and I got the connect to iTunes Screen. I tried several times to restore it via iTunes and it goes through the motions of software and firmware update but at the end of it all, it gives message that iPad can not be restored. The last few lines in the update log File are as listed at the end.
I now have iPad Pro but I would like to get my iPad 4 working again. The Apple shop have been their usual total waste of time self as all they are interested in is selling me a replacement iPad 4... so all I got from them is the usual salesman BS.
I have already tried all the Apple recommended procedures. i will be grateful for any tips on what the problem may be and how to fix it.
many thanks.
15:12:06.0686] ==== device restore output ====
[15:12:06.0686] (null)
[15:12:06.0686] ==== end of device restore output ====
[15:12:06.0686] AMRAuthInstallDeletePersonalizedBundle
[15:12:06.0795] <Restore Device 000000005583E9F0>: Restore failed (result = -1)
[15:12:06.0811] Can't send dump_console command since device is not in recovery mode
[15:12:06.0811] Finished RestoreOS Restore Phase: Failed
[15:12:06.0811] State Machine Dump, status:ERROR - [state:Recovery remaining-cycles:0] -> [state:RestoreOS remaining-cycles:0 (current state)]
[15:12:06.0811] Changing state from 'Restoring' to 'Error'
[15:12:06.0811] State is now set to error: AMRestorePerformRestoreModeRestoreWithError failed with error: -1
[15:12:06.0811] Restore completed, status:-1
[15:12:06.0811] Restore Checkpoint Fingerprint: 1303.FFFF
[15:12:06.0811] Failure Description:
[15:12:06.0811] Depth:0 Code:-1 Error:AMRestorePerformRestoreModeRestoreWithError failed with error: -1
[15:12:06.0811] Depth:1 Code:-1 Error:Failed to handle message type StatusMsg
[15:12:06.0811] Depth:2 Code:-1 Error:failed to update device firmware
[15:12:06.0811] Depth:3 Code:-1 Error:ramrod firmware update failed
[15:12:06.0811] Depth:4 Code:1004 Error:update_baseband: failed to perform next stage
[15:12:06.0811] Depth:5 Code:52 Error:Failed creating a communication transport to baseband.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@al_2015 … with my experience, when itunes wont restore via update, the traditional way. one can put the device in dfu mode and factory reset the device with success. this is not a restore. it will erase everything on the device, clear any faults and reinitialize the device with the latest software available. This usually clears all software related issues and functionality. the only time this has failed for me is when there is hardware failure that needs to be addressed.
this is the first step that apple and many techs utilize as it is the fastest way to determine software vs hardware issues. here is a link for some insight:
https://www.youtube.com/watch?v=IMaD_vz5...
这个答案有帮助吗?
得分 1
3条评论:
Thank you so much… I tried this DFU and I’m afraid it failed again with similar error message to what I listed earlier. So as you say, there must be a hardware issue. The log file is saying firmware restore failed. Is there any way of determining from the log file which hardware component is failing?
完成的
What does this mean?
完成的
@al_2015 ... error code 52 is typically an issue with onboard ram. i believe your nand is corrupt and preventing the chip from being overwritten and/or communicating with the software from itunes.
完成的
添加一条评论
添加你的答案
Ali 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 25
总计 2,080
