跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1989,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
204 个问题 查看全部
Display issues on MacBook Pro 2018 15"
I have thick green lines appearing vertically on the screen on the login window. After I login I see random flickering blue lines on the screen. I have updated the MacOS to the latest version, reset PRAM and NVRAM but the issue still exists. What might me the reason?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
8条评论:
hey! i am facing same issue u gotwhats the solution to this?
完成的
@Muaz - If you still have AppleCare+ I would go to Apple to get the display replaced as it will be cheaper. Otherwise you'll need a new display assembly 2018 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换
完成的
I dont have under apple care+ man.maybe i was wondering if it was MacOs problem because it used it with care no physical damage was done etc or maybe it will fix it by it self.dont know only harsh can tell me the conclusion because it just happened to him month before.
Some times it all prefect even start up screen was perfect during macOS update.
If this gives u any clue
If avoid blue area that pops up in start up for normal usage there is no problem at all no flickering etc.but it starts flickering when around that area is used for rendering any clue!
I want to avoid replacement bad af because just bought this laptop few weeks ago! I rather buy 4k/ 2k 144Hz monitor then getting new display
完成的
This issue has been happening to hundreds of people, I paid huge for a top of the range MacBook Pro and it barely lasted the two years and the screen did the same thing. It’s a manufacturing fault that Apple won’t admit. The opening and closing of the screen destroys the thin cables that attach the LCD to the main body, it is moulded together so in the past you could replace the cables but now they force you to pay for an entire new display which costs 50% of the entire price of a new machine. It’s got nothing to do with software or updates don’t be a fool. Apple refuse to acknowledge their manufacture fault and are raping the consumers blindly. I will NEVER purchase another Apple Mac again. Wasted my money and time.
完成的
Mine fell to pieces about 2 weeks before the 2 year warranty was up, but we were in strict lockdown and I couldn’t get my computer to a dealer. When I eventually got my computer there they weren’t interested in helping me. Mine was the latest Touch Bar. I spent a fortune and they gave me a faulty machine and did nothing about it. Goodbye Apple
完成的
显示更多的3条评论
添加一条评论
1个答案
This is a tough one! The bar is telling me the T-CON board has failed, and the sporadic horizontal line could also be a logic board issue with the VRAM.
Best to get this system to an Apple Store or authorized service center as it could be costly. Get an estimate first before you let them fix it.
这个答案有帮助吗?
得分 0
2条评论:
T-CON issue is same as the flexgate issue? Also any idea how much will repair cost me? The machine is out of warranty.
完成的
No, different! FlexGate was a ribbon cable which happens to connect to the board in question which powers the backlight. In this case there is also logic on this board deals with the raster of the signals to the horizontal and vertical lines that make up the LCD panel. This is the logic that has a problem here. Review Step 18 in this teardown 带功能键版本的 MacBook Pro 13寸 2016年末款拆解 Apple uses the same logic across the 2016 13" & 15" through to the current 2020 16" systems.
完成的
添加一条评论
添加你的答案
Harsh Khajuria 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 21
总计 2,201
