跳转到主内容
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
577 个问题 查看全部
Fake charging after battery and digitizer replacement
Hey Guys,
Looking for some advice please . My Ipad Air 1 64gb wifi only had an issue with holding charge. it would only run for few minutes unless plugged in to charger. if it ran out of battery and you plugged it in it would jump straight to say 67% charged and in a few minutes be at 100% charged. It worked fine while plugged in unless under heavy load say playing games for 45 mins plus.
I’m very new to this and If my first time doing something like that this (i’m quite happy working on PC’s), i decided to have a go at replacing the battery. I’ve done that and replaced the digitizer (as the screen removal process didn’t go so well!).
Before sealing it back up just testing it. Now when i turn it on its at 1% battery and when i plug it in it jumps straight to 5% battery and stays there. Screen/digitizer works fine.
I’ve watched a lot of videos about tristars, gas gauges, ICs and potential charge port replacement. Now I dont think i’m ready to get in to microsoldering but i would quite like to try and see the repair through.
So are there any quick wins here - could i just replace the logic board with a presoldered charge report perhaps? Presumably this is not most cost effective way? But there is nothing on the ipad i need to save, it was just used for games,
if there any thing else i should be checking that i may have over looked?
Should I just give up and stick it on ebay!
Many thanks in advance folks
Robert
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello there,
If the iPad was charging before it’s unlikely a Tristar or charge port related issue. Open the iPad again and disconnect the battery. There are plenty of very small components, microscopic components you could’ve knocked out around the charge / battery connectors. Have a look around those connectors for any missing components
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
senseless_wino 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 90
