跳转到主内容
The Acer Nitro 5 AN515-53-55G9 is a laptop targeted towards budget gamers. It boasts 256 GB of storage, Nvidia GeForce Graphics and an Intel i5 quad-core processor at a more affordable price than most gaming laptops.
60 个问题 查看全部
Nvidia Graphic card is not detected in windows 10
I can't find nvidia display adapter in device manager and i am not able to open nvidia control panel. When i try to reinstall Nvidia drivers, it says nvdia gpu not detected. Can anyone help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi,
Did you check in Device manager > View > Show hidden devices or in Device manager > Other Devices (if listed) just in case it is listed there for some reason?
Don't know the laptop, but check in BIOS (press F2 when Acer logo shows on startup - I think) to see if there is an option to turn on/off the Nvidia graphics adapter. If there is enable the adapter, save the changes and restart the laptop and check if it appears in Device Manager.
If there is no graphics option in BIOS, try resetting the BIOS to the default values, save the changes and then restart the laptop and check in Device Manager.
If still not there it may be a faulty GPU IC. Usually laptops don’t have a plug in GPU, it is either integrated with the CPU or where there are two GPUs in the laptop, one is in the CPU (Intel in your model) and the other is hard mounted separately on the motherboard.
Replacing a hard mounted GPU is not easy. It is easier to get a replacement motherboard
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Uday 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 18
过去 30 天: 78
总计 3,624
