跳转到主内容
Repair guides for Android cell phones manufactured by ALCATEL.
991 个问题 查看全部
My phones not charging anymore
My phone is not charging anymore it had a cracked screen when I dropped it a while ago but it still worked but now my charges don't work to charge this phone but there's nothing wrong with the chargers its just my phone do you know how much it will cost to make it work again please
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello. Charger problem is common with many new age phones. Over time the charging port gets pushed back and does not accept the charger. This is an easy and cheap fix (your repair guy might charge you 5 euros or so). If you open it up you will see for yourself what you have to do.
About the screen, I don't know your model number but a screen assembly usually sells for about 25-50. If you could give some additional info, we can provide a guide on how to replace it yourself.
If these two things are the olny ones that nee fixing, it shouldn't cost you more than 50 euros (if you repair it on your own, that is).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Phyllis Clifton-Grant Heka 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 42
