跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
Is this wire necessary?
I was replacing my optical drive in my Mid 2011 27” iMac.
I’ve done some repairs on similar models before. Whilst putting the LCD back on I accidentally damaged the CPU Fan Ambient Temperature Sensor Cable 593-1361.
I thought it wouldn’t effect the iMac as it was only a trigger for the fans, and that I would replace it later.
When I turned the iMac on the fans became very aggressive and the iMac booted halfway and then the LCD turned off but the fans continued aggressively, I tried putting the iMac into safe mode, but it didn’t work. I then tried putting it into Internet recovery mode, and it completed the spinning earth cycle but froze on the Apple Logo.
I understand the wire is most likely the problem for the aggressive fans, but surely not for the half-booting LCD? Is it because of the CPU Fan Ambient Temperature Sensor Cable 593-1361 or is there another issue?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
OS Safe Mode is different not the same as hardware Safe Mode.
完成的
添加一条评论
1个答案
Yes! The sensor is needed!
SMC requires the input, if it doesn’t see it SMC will push the system into Safe Mode, pushing the fan to the limit and lower the CPU’s clocking to a crawl!
这个答案有帮助吗?
得分 0
9条评论:
Hi Dan, so It'll use the fan alot and lower the CPU, but why does it stop the mac from booting up?
完成的
What where you doing to your system?
完成的
Nothing, The DVD. player. wasn't working so I replaced it
完成的
OK, what drive did you put in?
完成的
GA32N SATA Superdrive @danj
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Jup K 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 76
