跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
Intermittent 'No Service' Signal issues - loose antenna connection
Hi,
Recently my iphone 3gs has got really bad signal it does intermittantly from fulls signal-to just a bit-to no service and sometime stays on no service for a good while (pretty annoying). I took it in the local phone shop today and they took the front off and said something to do with the signal antenna was a bit loose and they had pushed it back in to place. This gave me full signal but about 10-15mins later the problem was back. They said if it returned they could re crimp something? this will cost £20 though as was wondering if there is a simple safe way I could make this connection better?
Many thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
If they charged you for the first fix, which now has gone bad. Return and have them fix it properly for no charge.
完成的
添加一条评论
1个答案
已选择的解决方案
Brad has got the right idea, some nerve of them to charge you for their improper fix.
HOWEVER! If returning to that shop is not your idea of a good time, feel free to check out this Answer. It seems "connector 7" would be the culprit. You can follow this guide up to step 10 to find that connector and try to get it to seat right. The answer also has some repair tips. Hope this helps!
这个答案有帮助吗?
得分 0
1条评论:
They didn't charge me for just putting it back in place the first time they just said try that and if it continues come back and they will sort it (although that will cost). Will try that guide would you say it's ok for someone with no previous knowledge to follow-difficult to damage the phone further?
完成的
添加一条评论
添加你的答案
Josh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 4,772
