LG plasma tv randomly shutting off
LG Plasma model 60pa6550 randomly shuts off. Sometimes when turned back on there is no picture but sound. Will randomly do this after being on for minutes or hours.
Hi @bks5300 ,
Sorry I can’t be of any more help on this one.
Here’s the service manual which may help you or someone else who sees this post. (Be patient when going to download as it takes a little while to go from processing to download - this is the download link- after you have passed the recaptcha test and clicked on Go to Download, below the document preview box)
Unfortunately it seems that some specialized tools and software is required to test the TV, apart from some basic voltage tests on the power board. To that end you may spot something if you disconnect the power from the TV and then remove the back cover and check the boards for any obvious component damage, i.e. heat stressed components, leaking or bulging capacitors etc.
Random faults are never easy to find but you may get lucky.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 493
Hi @bks5300 ,
What is the full model number of the TV, LG 60PA6550-UF, or LG 60PA6550-UG?
由 jayeff 完成的
lg60pa6550-um
由 Brooke 完成的
Have the same problem with my LG60PA6550 UM .... Any advice you can share please!
由 Tony 完成的
