跳转到主内容
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
375 个问题 查看全部
iPhone XS Max randomly turns off after around 5min (Not Charging Port)
Hello,
I have an iPhone XS Max brought in by a customer that randomly turns off after 5min. I have looked at previous answers that have said the issue is the charging port however in the two cases I have, the iPhone has never been opened and thus the charging port is OEM, the same one that came out the box.
I have replaced the battery which worked for around a week before eventually reverting back to randomly turning off. I also have replaced the charging port just to check. I used another OEM one and the issue persists leading me to believe its the motherboard.
Upon inspecting the motherboard I haven’t found anything significant however maybe i’m looking in the wrong direction.
If anyone has had this issue before and fixed it please let me know! :-)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
+ In one case the iPhone has been dropped, the back cracked but aside from that, fully functional. In the second case the iPhone wasn’t dropped or anything, the problem just developed.
完成的
添加一条评论
1个答案
最有帮助的答案
It could be a lot of things causing it. I would recommend putting the board into a known good housing with known good screen to completely eliminate parts.
You could try and look at the log to see what it was doing before shutting down.
这个答案有帮助吗?
得分 1
2条评论:
Will try this and update you
完成的
Did u fix it?
完成的
添加一条评论
添加你的答案
David 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 443
