跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
Add SSD or Replace Superdrive
Hi,
I want to buy the latest iMac "27 i7 and add an SSD (maybe a Vertex 3).
Do I have to replace the superdrive or is there a second hdd connector?
If I have to replace the superdrive, what tools are needed?
And what caddies should I buy? (compatible and with good quality)
Thank you.
Alak
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If you can verify that your iMac has the necessary mounting points, you can use this kit (see link below) to install the SSD drive while retaining your Super (DVD) Drive.
http://www.yourmacstore.com/internal-ssd...
If the above won't work for you and you don't want to mickey mouse mount the SSD, you can use OWC's data doubler kit to replace the Super (DVD) Drive (link below).
http://eshop.macsales.com/item/Other%20W...
If you go the above route, you'll also want to make sure the SSD is connected to the SATA III port on the main board of the iMac since only 2 of the 3 SATA ports on the Mid 2011 iMac are SATA III compliant.
Although, this is only relevant if your SSD is SATA III.
这个答案有帮助吗?
得分 2
1条评论:
Found this too from maxupgrades.com:
MaxConnect SSD bay Hard Drive kit for 2.5 inch Drive for [2011] iMac 27 Models - SZ-IMACSSDBAYMT-02 - http://www.maxupgrades.com/istore/index....
It should do the job if you don't have the necessary mounting points for the SSD bay.
Unfortunately I couldn't locate any pictures of the part.
完成的
添加一条评论
添加你的答案
Alak 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 5,069
