跳转到主内容
Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
210 个问题 查看全部
Is my Apple Watch even possible to repair? (Series 3 LTE)
(Series 3 LTE watch) I went to a computer store that was an Apple certified tech, And I showed them my watch but it was dead at the time, but the guy agreed to look at it anyways, they never actually charged it and looked at the display, but he informed me that my watch display was the reason my touch screen wasn’t working because it has a big crack but when you look at the actual display when it’s on there’s no distortion and there’s no display issues whatsoever the glass is cracked the top section of the touch works but the bottom let’s say 75% is unresponsive. I’m curious if there’s actually a repair for this Or if the Apple tech is in fact correct and the display was the reason my touch screen was only partially working. I just have this weird feeling they just wanted to rush me in and out of the store and tried to up sell me on a brand new series 5. Tried to include pictures of display and angled view of crack
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The display is a sandwich of parts: the crystal, the touch plate and then the OLED display. Clearly your crystal is cracked and I often find the touch plate can often get damaged as well.
So the tech wasn’t giving you a song and dance and most likely they don’t fix watches in-house so its off to the Apple repair depot to be repaired!
这个答案有帮助吗?
得分 1
3条评论:
I guess to add more of a point to my question, if I replace the glass and touch pad or whatever makes it touch screen, the touch screen works again yes? Cause the person made it seem like even if I did replace said components it would likely still not function, which is what generated my confusion as a naturally skeptical person it seemed strange something not being repairable ..
完成的
Here's the guide to replace the display assembly which offers the crystal, the touch plate and then the OLED display as a complete assembly 苹果手表屏幕更换
Replacing it should fix your display issue. The only thing that could mess you up is water or other liquid find its way in or not using care in the repair its self.
完成的
Thanks dan! I think I’ll pick up the kit and try and replace the screen myself
完成的
添加一条评论
添加你的答案
Spencer Dunfield 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 159
