跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Removing WiFi ic chip on motherboard
Hi guys quick question
ive been looking on YouTube about the WiFi chip on the 6s plus. Some show the chip needs to be programmed and some doesn’t show it. My issue is the WiFi isn’t working. The repair guy also mentioned about programming. Just wanted to know if that had to be done. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The Wi-Fi chip needs to be unbinded. I usually do this by removing the NAND which is where the information is stored and reprogramming it to unbind the Wi-Fi serial number. There are other programmers out there that claim to accomplish this without removing the NAND but I cannot comment on those as I have never used one.
这个答案有帮助吗?
得分 1
3条评论:
Yes because one of my repairers are telling me they can do it without programming and the other said they need to reprogram the chip. I don’t know which one I should for? Anyone else have any input to this.
完成的
You don’t need to program the chip. You just need to un-bind the old ones serial number from the NAND and it will automatically write the new serial number when booted.
完成的
Okay so if I was to get a new WiFi chip and solder it to the board. It will just. Automatically read the serial. Also how I’ll I go about unbind img th old serial number?
完成的
添加一条评论
添加你的答案
Rakesh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 588
