跳转到主内容
加入维修社区 - 创建账户
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
Boot Camp stopped working?
Hi all .
I have a customers MacBook Pro: 15” MacBook Pro 2.8 GHz Core i7" Mid-2015 (DG) they want boot camp installing with Windows 10 Pro.
I have lost count how many machines I have set up with parallels and boot camp.
So I’m fully aware of the entire process start to finish. But on this occasion no matter what I do, in what order I keep getting this result, see image.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
What do you see within macOS Disk Utility? Remember with APFS you need to now create a new partition Vs a container within the partition. Review this How to partition a Mac hard drive or SSD, or create a APFS volume
这个答案有帮助吗?
得分 0
4条评论:
cant show you at the moment, have just initiated another clean install.
shouldn't the boot camp assistant sort all that out though?
and when at the screen i put in the image it should just install to the allocated partition.
the image i provided i admit doesnt show a label on the windows partition. i think i had deleted the partition at the point of taking the image.
完成的
@chuxsta - It depends on which version of macOS you are running on the system and the version of BootCamp you are using.
完成的
@danj i tried boot camp in Catalina, Mojave and then High Sierra. got the same error on all.
then tried re-burning my windows ISO in case that was corrupt.
customer has taken away with just Apple OS installed for now as they needed it for work.
but i will have it back at some point to try and solve this.
完成的
You may need to scratch the drive down and start anew.
完成的
添加一条评论
添加你的答案
stuart 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 9
总计 135
