跳转到主内容
Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
What adhesive tape to use for Surface Pro 5?
I am replacing the battery on a Surface Pro 5 and re-using the screen assembly.
Does anyone know what type of adhesive tape would be best for re-assembly.
I want to find out what is close to the factory tape in thickness, adhesion, and type as possible. Any recommendations would be greatly appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I’ve always used Tesa tape brand (link below) with excellent results. Its the right thickness and holds very well.
I mostly use 2 and 4 mm.
Tesa 61395 Tape
Custom cut rolls of Tesa 61395 double-sided tape for repair.图片
产品
Tesa 61395 Tape
$5.99
这个答案有帮助吗?
得分 1
2条评论:
Perfect, this is what I have on hand from a previous Surface Pro 4 repair.
Did they change the tape to a thicker foam type tape for the Surface Pro 5?
I thought I read somewhere that it's different the previous models.
完成的
That I do not know. I've just had great look with Tessa tape on all repairs that either dont come with precut adhesive or need a little bit more applied.
完成的
添加一条评论
添加你的答案
William Blalock 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 958
