跳转到主内容
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
87 个问题 查看全部
Why is my screen black with no response?
A customer recently brought me an iPad Air 2 in good condition saying it just stopped working one day. There is not visible damage, and everything externally looked fine. The iPad gives no response when plugged it, doesn’t turn on, and doesn’t pop up in devices when connected to my computer. I have tried all the basic resets and just replaced the battery with the same result. I was wondering if anyone else had come across this problem and knew if it was possibly a blown chip on the logic board, a bad screen, or a battery issue. Any feedback is appreciated. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Well you did rule out a bad battery by the sounds of it. If you have a known good screen give that a shot. If you have a DC power supply, try hooking it up to that. If it draws amps before you even press the power button, then there’s a short before it’s prompted to boot, and can prevent them from turning on. You could send it to iPad Rehab or STS Telecom for further diagnosing and or repairs if necessary.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alec Thompson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 27
