Power + Charging LED come on when power button pressed, but no boot
Let me start off by saying this is actually a Lenovo B50-10, not 80. iFixit did not have this model listed on their device list.
I can get the battery to charge, and I can tell it has over 20% charge as the LED indicator went from orange to white. When ''''I try to power the machine on using the power button I get a white LED from the power indicator and an orange LED from the battery indicator, but no boot. I can feel the CPU getting warmer each time I attempt this.
I have unplugged CMOS and the battery and held down the power button for 20 seconds but this did not fix it. I have tried the bare minimum number of components plugged in (just battery and LCD) and still no boot. I have reseated the RAM. What could be causing this? Is the power button not communicating that it wants to boot and I just get LED indicators instead?
3条评论
Have you tried taking out the battery and attempting to power up with just the charger plugged in?
The battery could be defective
由 mike 完成的
Yeah, it does the same thing, only without the battery LED lighting up.
由 Panda Tech RMA 完成的
@ptrma
So I take it you can't even get into the BIOS?
Did anything suspicious happen before this problem appeared?
Any clues?
Are any of the lights blinking. Look at User Manual for codes for lights page 9.
Have you checked out the Service manual?
https://pcsupport.lenovo.com/cr/en/produ...
Is the charger working proper? Correct voltage?
由 mike 完成的
