跳转到主内容
加入维修社区 - 创建账户
任天堂于2019年9月20日发布了在Switch系列中更加实惠、且更纯粹的掌上游戏机——Nintendo Switch Lite,它有着一体式的手柄设计以及更小的屏幕。
Adhesive foam for digitizer
I easily found a replacement digitizer for my scratched one on my Switch Lite (they’re all over ebay and Amazon), but it did not come with the adhesive foam to attach it to the LCD and the case. I can’t seem to find this foam anywhere, though I did see replacement foam for the regular Switch. Is this foam available somewhere or is there another solution for replacing the digitizer?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
I ended up using pieces from the Tesa 61395 card that iFixit sells. I did this for the outer ring of adhesive, the part that attaches the digitizer to the Switch itself. For the inner ring of adhesive, the part that attaches the digitizer to the LCD panel, I was actually able to carefully remove the old foam from my scratched digitizer and reuse it. It actually came off the old digitizer pretty easily when I carefully removed it with tweezers. I couldn’t salvage the outer ring in this way, though.
完成的
my inner foam tape is barelly sticky, is it supposed to be like that?
完成的
添加一条评论
4个答案
Try some adhesive tape rather than the foam
这个答案有帮助吗?
得分 0
添加一条评论
did you ever find it? i need it aswell
这个答案有帮助吗?
得分 0
添加一条评论
sorry to revive an old question but did anyone ever find any of this foam? Or is Tesa Tape good enough? I’ve got a switch lite digi to replace but the owner already attempted it themselves and binned the old Digi along with the foam so I need to get replacement
这个答案有帮助吗?
得分 0
1条评论:
The tesa tape works fine.
完成的
添加一条评论
Did anyone ever find the sizing you need? It comes in multiple mm thicknesses
这个答案有帮助吗?
得分 0
2条评论:
I think its 2mm
完成的
Thanks mate!
完成的
添加一条评论
添加你的答案
strells 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,337
