跳转到主内容
加入维修社区 - 创建账户
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
How do I replace audio flex cable
I would like to replace audio flex cable on 2017 MacBook Air 13 inch laptop. Where can I buy part?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The 2017 is the same as the 2015 all thats different is Apple had to update the logic board to support a newer CPU and Intel EoL the one they where using.
The I/O board is where the headphone jack is located as well as the audio DAC (Cirrus chip) MacBook Air 13" (Mid 2013-2017) I/O Board The cable which connects the I/O board to the main logic board is MacBook Air 13" (Mid 2013-2017) I/O Board Cable Here’s the guides for both
Replace an I/O Board Cable compatible with the Mid 2013 to 2017 13" MacBook Air laptop. Fix the connection between the I/O Board and the Logic Board.图片
产品
$14.99
Replace a used I/O board compatible with the Mid 2013 to 2017 MacBook Air 13" laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe 2 power, USB, and audio ports.图片
产品
$52.99
MacBook Air 13" Early 2015 I/O Board Cable图片
指南
MacBook Air 13" Early 2015 I/O Board Cable Replacement
难度:
中等
15 minutes - 1 hour
MacBook Air 13" Early 2015 I/O Board图片
指南
MacBook Air 13" Early 2015 I/O Board Replacement
难度:
中等
35 minutes
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brendon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 116
