跳转到主内容
Released December 3, 1994 in Japan and September 9, 1995 in North America. Models SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x, and SCPH-900x.
Spindle hub cap cannot spin cd properly
Before telling the main problem, I have replaced the spindle hub.
Now the spindle does not spin properly and the cap is detached when you put out the cd. I will give you the video for more understanding
I ‘m thinking about applying a super glue on the spindle cap so it can spin properly. Is it okay?
https://youtu.be/DtRF_NGTM9M
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I viewed your clip and it sounds like the disc is scratching against the flat part of the bay. Try adjusting the height of the spindle. It should spin smoothly after doing so. Your video shows that the spindle is pushed way too down. The top part of the spindle must be at the same height as the “needle”. Btw the part you removed must spin with the circle underneath it. Apply a small amount of super glue without applying some to the rubber part. Doing so will ruin the CD locking mechanism. Or just buy another spindle but this time, use a flat object when installing to perfectly align it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mahdiar Naufal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 218
