跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
Cannot receive incoming calls
iPhone 6s plus cannot receive incoming calls. It goes straight to voicemail. Outgoing calls and going on the internet works just fine. I tried swapping another simcard, my own working simcard and resetting network settings. Still the same. Has anyone seen this before
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I have run into this before. Are you calling from close proximity? Get someone to call you that are on a different network and on a different tower. I once spent hours on this issue. I did notice when I called in close proximity the 4G symbol turned to 3G and going straight to voicemail. When I got someone to call me in another suburb it was fine.
这个答案有帮助吗?
得分 1
1条评论:
Tried it with several working simcards on different carriers and also people from other areas calling the phone.
完成的
添加一条评论
添加你的答案
KWH 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 67
