跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Front Camera not working after replacing screen
I replaced my iPhone 6s Plus’s screen including camera, sensor [works], and call-speaker [works] with OEM.
All flex cables are intact and undamaged.
I’ve read some posts about that it might be related to a grounding bracket.
I can’t find any information about the location of this bracket on the 6s Plus.
Any idea what might be causing it and how to fix it?
Things i’ve tried:
Force closing Camera App.
Restarting Phone.
Settings Reset
Factory Reset
Upgrading to latest iOS [13.6]
Using different video apps [Facetime & Whatsapp]
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Have you tried to put the old front cam from your old screen to the new, maybe the cam on the new screen is defect? Or is the old front cam also defect? This is the first thing you can try.
这个答案有帮助吗?
得分 0
6条评论:
The old camera's flex cable was broken which is why I replaced it.
So I can't test this, unfortunately.
完成的
Try to take the new cam of the screen and put it back on, maybe it wasn’t put correct in by factory
完成的
@Leslie Leslie
I actually disassembled those parts when it didn't work.
It all looks good.
完成的
Only thing that left is to buy a new front cam and try that one. I don’t think it is a grounding problem. You might have received a screen with bad / defect front cam.
完成的
@Leslie Leslie
That's true but I hate paying for it if it doesn't fix it.
Unless there's a good return policy :P
完成的
显示更多的1条评论
添加一条评论
I just did a System Info check using Cydia and it does show a serial number for the front camera.
UPDATE: I decided to buy a new Front Camera to see if that fixes the issue.
Will update asap.
这个答案有帮助吗?
得分 0
1条评论:
Replacing the camera with a brand new camera did not fix the issue.
Any more ideas?
完成的
添加一条评论
添加你的答案
Nigel 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 142
