跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
704 个问题 查看全部
left joy con joystick going down when pressing up.
Hi! so im having an issue with my switch where if i hold up on the joystick with any level of force it will start teleporting between fully up and fully down really fast. this started happening after i "dropped it while i was asleep"... or thats what i told my parents anyway in actually smash bros got me salty and i missed the bed (threw it) lol. i ended up deciding to take it as a learning oppertunity and decided to grab a repair kit from amazon and see what i could do. once it arrived tho i replaced my joystick with both of the replacements in the kit and everysingle time the same problem persisted, it would always flash between up and down when holding up with force. after many calibrations and factory setting restores i eventually factory reset the whole switch and still the problem persisted.
for me this rules out 2 things. 1 : it cant be the joystick because it was happening on all 3. 2 : it cant be software because god knows i did everything i could with the software and the problem persisted.
the only thing i can think that it might be now is possibly a motherboard malfunction?
if anyone has some words of wisdom please let me know as i cant find anything else about this online
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Unfortunately it sounds like it’s a motherboard issue. You could try cleaning the terminals where the joystick ribbon cable is inserted. The pins on the same socket might be another thing to check. Nintendo fixes all joy cons for free but unfortunately you voided the warranty by opening it to fix it yourself. might be worth trying to set up a repair on their support website though.
这个答案有帮助吗?
得分 0
添加一条评论
I calibrated the console and controllers in settings and now it’s working fine
这个答案有帮助吗?
得分 0
2条评论:
Did you fix it?
完成的
Hi I have this same problem but how tho did you take it apart or but go to settings??
完成的
添加一条评论
添加你的答案
Fusion pro 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 31
总计 1,246
