跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
706 个问题 查看全部
Can someone help with stripped screws?
While attempting to maintenance my brothers switch I ended up stripping a screw on the backplate. Is there ANY way that I can remove it without damaging the backplate? I used an iFixit kit but the console is refurbished so I guess they tightened the crews too much. Any working methods besides rubber band or superglue will help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
How bad is it? In my experience, I’ve been able to get away with using a slightly larger bit and applying lots of pressure to remove mildly stripped screws. It may be too rounded out for that to work, however. Is it a tri wing security screw or a regular Philips?
这个答案有帮助吗?
得分 1
1条评论:
Triwing, I just ended up drilling it out
完成的
添加一条评论
添加你的答案
Woodroe Mitchell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 80
