跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
678 个问题 查看全部
Black shadow appears at the lowerend of my iPhone 8+ screen?
So my phone hasn't been dropped recently tho I did receive it through a courier service but it was tightly packed, there's a black sort of shadow that appears on the lower end of my screen only sometimes, it quickly disappears if I readjust my brightness. First time it appeared I restarted my phone and it was normal for quite a while and it appeared again but I changed the brightness and It got normal again. I'm concerned is this going to get worse and is at a hardware issue ? Do I need to be concerned ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I would remove the pentalobe screws and lift the screen and see if the shadow goes away as there could be something underneath causing a bit of pressure. You would then have to rule out a faulty screen. If a replacement screen is still the same it will be one of your backlight circuits that has failed. I have had a few like yours on the 8 plus but the shadow was larger.
 If you are familiar with a multimeter you could check the six pins in the red square on the LCD connector. If any of them read “OL” it will be a backlight issue on the logic board and a replacement screen will not help.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
amna.bokhari 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 909
