跳转到主内容
加入维修社区 - 创建账户
第六代 iPad 发布于2018年3月。拥有无线局域网和无线局域网+蜂窝网络机型,32GB 和 128GB 两种储存容量可供选择。配备了 9.7 寸的 Retina 视网膜显示屏和 64 位架构的 A10 Fusion 芯片。
Will not charge IPAD
I tried switching power cords but it still will not charge. I even turned it off and powered it on by plugging in a power source, so I know the power receptacle is working. My battery is my next option. So the question is, how do I get the battery to Hawaii?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
What he said ^^ bring it to a shop with a tristar tester and they will be able to tell you which of the three it is.
这个答案有帮助吗?
得分 0
添加一条评论
If you have used non-Apple cables, you may have damaged the charging portion of your board.
Even if the battery is bad, the iPad should power on with the cable connected which leads me to think it’s either your cable (that’s gone bad), the port is damaged some how (you need to look at the pins), or the charging chip on the board is gone.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bgaralde 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 11
总计 125
