跳转到主内容
The HP Spectre 13-3010dx is a high end, lightweight, HP touchscreen laptop.
13 个问题 查看全部
chip malo spectre 13-v111dx
el chips de 10 pin marcado en la mother board como SD36 y SD41 al lado de conector usb de energía esta marcado como 96……usted sabe el código de este chips para ser comprado?. Gracias.
the 10 pin chips marked on the mother board as SD36 and SD41 next to the usb power connector is marked 96 …… do you know the code for this chip to be purchased? Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
What is the motherboard's "board number"?
Try searching for (insert motherboard 'board number') schematics to see if there are any schematics available online that may help to identify the components
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marco Rifo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 68
