跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
Horizontal lines, and black screen with sound
Recently my Switches screen started acting up out of nowhere. When I power it on or wake it the screen is covered in multicolored horizontal lines with a sort of grid pattern, after about 1-3 seconds the screen will go black with backlighting still present. The digitizer seems to work perfectly as well, and the Switch functions normally when docked. This problem seems to have appeared out of the blue with no forewarning. It seems to have occurred in the span of about 5-10 minutes. I plugged my switch into the charger and left the room for a moment, upon returning the screen was completely covered in the aforementioned lines. I’m not sure if it’s an issue with the lcd or possibly an issue with the motherboard. I opened the switch up and there doesn’t seem to be any issue with the ribbon cables or connection. Any help would be very very much appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
4条评论
I have same issue on my switch lite
完成的
Hello did you solve your problem with the switch screen? I'm having the same issue with my switch lite and it came out if nowhere.
完成的
Same just happened to me yesterday without me dropping it or anything happened out of the blue just like that
完成的
I have this exact same problem, it came out of nowhere while someone was playing on it today. The screen also seems pixelated in some way, I'm gonna try to do something with the LCD flex cable.
完成的
添加一条评论
4个答案
已选择的解决方案
I reseated the LCD flex cable for the display carefully and that seemed to fix the problem for me. It only occured when I unplugged the display cable from a previous repair.
If reseating the display connector does not help the display most likely needs to be replaced:
任天堂 Switch LCD更换
Nintendo Switch LCD
Replace a damaged or malfunctioning LCD display panel in a Nintendo Switch.图片
产品
Nintendo Switch LCD
$49.99
这个答案有帮助吗?
得分 2
2条评论:
Thanks for the advice I’ll give it a shot, not sure how the cable could have been dislodged, possibly overheating?
完成的
The cable shouldn't go loose by itself as it is locked into place with a zif-flap connector. Worst case it would be the screen going faulty and needing to be replaced.
完成的
添加一条评论
All i know, i lived in jamaica and my switch have lines, and i don't know how to fix it, All i gotta say is goodbye switch, my aunt gave me this nintendo from another country, bye nintendo, bye youtube, bye fortnite😞
这个答案有帮助吗?
得分 1
添加一条评论
my switch lite have that issue. when some ants get inside of my switch lite.i think the ants the to eat the ribbon. thats why im getting that issue.
这个答案有帮助吗?
得分 0
添加一条评论
This problem happened to me suddenly mid gaming and seems to get worse the warmer the console gets. I wonder how could this happen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Laurence Zeffler 将永远感激不已
浏览统计数据:
过去 24 小时: 33
过去 7 天: 252
过去 30 天: 1,243
总计 45,219
