跳转到主内容
加入维修社区 - 创建账户
发布于2011年7月21日。Core i5或Core i7处理器。雷电(Thunderbolt)接口。本机也用于Mac mini Server配置。
Mac mini 2011 won't boot and vertical lines.
My macmini is suddenly got verical lines on screen. And then problem with start up. I cannot go to recovery Mode. I can go to safe mode. But i don’t know what to write there to be able to go to recovery mode again. When i go to recovery i see the globe but after the indicated time is finished the screen turns to white. Can anybody please help me what to do? Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
Can you tell us which model you have Apple produced two versions:
Macmini5,1 - HD Graphics 3000
Macmini5,2 - Radeon HD 6630M GPU
完成的
Hello Dan, thank you. Can you please tell me where can I see that.? Because I cannot go to the computer. It can not boot correctly. I have the box. The model is A1347. Is it this one? Or can I see it from the safe mode? Please help me on this. I am not very familiar with apple.
完成的
Locate your systems S/N from the system and plug it in to here EveryMac - Lookup
If you can get into Safe Mode then look at the About This Mac and then click on the System Report button click on the Graphics/Display section you should see one or two Video Cards listed.
完成的
I have the box. On the box i see that the s/n begins with CO
Macmini is 2.5, BEL/IEA. Can these information be needed to see the graphic card model. I will also try to single user mode (control s) to give you more details. I also did a hardware test that said no hardware issues found. Is that a good sign or not. Idk. But still vertical lines appearing and no recovery mode able. I appreciate your help.
完成的
Command s and i see just bunch of lines (like dos in windows) and then i have to write syntax language. My question is if i cannot solve the problem with syntex, which syntax command should i write to have at least the recovery mode back? Is that possible? Because i have no access to recovery or whatever but this. Thanks in advance
完成的
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
Sadly your logic board has failed, you’ll need a new one Mac Mini Logic Board, 2.3 GHz i5 - Intel 3000 I would recommend getting this version of board as it will last a lot longer than the Mac Mini Logic Board, 2.5 GHz i5 - AMD Radeon 6630M version.
Here’s the guide you’ll need to follow Mac mini Mid 2011 Logic Board Replacement
这个答案有帮助吗?
得分 1
2条评论:
Ok. That means no remedy but just buy another one or repair. As repairing or replacing costs a fortune i think that the other option would be smarter. Thank you so much for your support.
完成的
Thank you for your support.
完成的
添加一条评论
添加你的答案
Macminime 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 891
