跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1990,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
Why won't my MacBook Pro turn on?
Computer was on and working fine. I closed it to move to another room and it would not wake up from sleep when I opened it. No lights, no keyboard lights, no fan, no noises. Tried hard shutdown by holding power key down. Left it closed overnight and it still won't boot up. Plugged it back into power and still no response. Tried resetting SMC, but of course that does nothing. Any suggestions?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
What is your charger? An original Apple unit or something else and are you using the original USB-C cable.
完成的
Original charger and usb-c. The battery was at about 90% when it wouldn't wake up.
完成的
添加一条评论
1个答案
已选择的解决方案
This is not sounding good ;-{
The power logic on the logic board has failed. You’ll need to visit Apple to see if they will cover it under warranty. If not you’ll need a new logic board.
这个答案有帮助吗?
得分 1
1条评论:
Thanks. I appreciate your help.
完成的
添加一条评论
添加你的答案
Wilma Lingle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 103
