跳转到主内容
加入维修社区 - 创建账户
Nintendo Switch 是一款掌上游戏机,可以通过底座连接到电视上游玩,也可以随身携带。于 2017 年 3 月 3 日发布。
micro sd card reader not working even after replacement
my micro sd card reader wasnt reading sd cards. so i purchased a replacement and repair kit from this website. followed directions and it still doesnt work idk what could be the issue but nintendo online repair is closed still and im just really annoyed things just cant work.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 7
添加一条评论
3个答案
最有帮助的答案
Same thing as I had for 2 years, for me it was that you need to make sure the connecter is fully pushed in. If it still doesn’t work it may be a faulty socket on the board (don’t quote me on that).
这个答案有帮助吗?
得分 4
添加一条评论
I was in the same situation. After closer inspection, my socket was bad. I had missing pins. So I had someone replace it for me and it started working again. Replacing the socket requires micro-soldering, beyond my skills.
这个答案有帮助吗?
得分 2
2条评论:
I'm in the same situation as you who fixed yours and how much did it cost
由完成的
It was local tech that I found off of OfferUp. He worked out of his home. He charged me $40 at the time.
由完成的
添加一条评论
I am also in the same situation. I did notice that while the switch is on, I can get the switch to detect the replacement reader if I press down on the connector at a certain angle. But I need a more permanent solution. I can’t be playing with the back open like that.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Luke Priore 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 38
总计 2,633
