跳转到主内容
型号为JSN-L21和JSN-L42
36 个问题 查看全部
phone heating and battery draining
i m using honor 8X 4GB 64GB varient.my phone gets heated up and battery drains fast even when i use to watch youtube or web searching.n heat comes from near the camera portion.help me out of it as soon as possible.thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
5个答案
最有帮助的答案
This might be a signal of some sort of hardware error. Have you ever tried booting the mobile in safe mode and perform the usual tasks that make your phone hotter(watch youtube in your case). Also, don’t forget to check if any app installed on your app is using your mobile/wifi data in the background. A weak signal can also cause your phone to drain your battery faster and generate heat as well.
这个答案有帮助吗?
得分 2
添加一条评论
Go into settings and battery to see what applications are primary users. Then adjust those apps in polling frequency - or even uninstall them. Other primary possibly unneeded battery users: Bluetooth, GPS (Especially indoors), WiFi when none nearby. Screen brightness. Volume.
这个答案有帮助吗?
得分 0
添加一条评论
I searched a little bit online.
Try the following steps to cool your phone down again,
1. Remove the phone’s case
2. Switch on airplane mode to disable all connectivity
3. Move it from direct sunlight
4. Direct a fan at your phone (but don’t put it in a fridge, freezer, or cooler)
5. Reduce the display brightness
Once you’ve done this, try the following to avoid further overheats:
1. Use Battery Saver mode
2. Clean up your phone to remove junk files
3. Reduce Wi-Fi, Bluetooth, and GPS use unless needed
Not only should your phone stop overheating again, but the battery should last longer! Beyond overheating, there are plenty of apps you can use to check if your Android is functioning properly.
这个答案有帮助吗?
得分 0
添加一条评论
  • My uncle present Honor 8x for me in 2019, and i dont have any battery & heating issues so far today .
  • I recommend don't upgrade your android versions
  • Because so many problems are arrived after you upgrade the android versions ,so don't do this....
这个答案有帮助吗?
得分 0
1条评论:
I d upgrade my own and My phone use to turn off by itself when ever connect to WiFi or mobile data and battery drain easily
What can I do?
完成的
添加一条评论
Working and phone power on phone but Android window seen but not opening 😔
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Raj rishi Nath 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 18
总计 1,462
