Random water output - Water left in Pod
My Keurig K40 is acting strange.
The water output varies widely!
I can press Large and get an espresso sized shot in the cup.
I can press Small and get an overflowing mug!
Press Medium and maybe get less than small.
And all this is without a Pod installed.
With a pod installed, a lot of liquid will remain in the pod…and same results as above.
I have cleaned all the needles, checked all tubing, valves and filters.
Could the computer logic be faulty?
Does anyone know if there is a logic board or a relay in these machines to control how long the pump moves water?
由 Monte87 完成的 分享
Sprayed compressed air through the rubber nozzle that spits water back into the reservoir tank.
There are two separate openings in the rubber nozzle. The Left one seems to flow to the output needle and water comes out when I flush air through.
The Right one seems to flow back into the water reservoir through the intake filter at the bottom of the tank.
Many users reported doing this fixed their problem but this has not worked for me!
Still there is water left in the pod after brewing and the water output levels are not correct and take a long time to come out.
Is the pump bad or could there be something wrong with the logic board?
Or could there still be a clog???
由 Monte87 完成的 分享
