跳转到主内容
2018年10月,谷歌发布的自有品牌手机Pixel的第三代产品。
103 个问题 查看全部
Thick vertical green line in display after replacing charging board
Hi - followed the instructions for the Pixel 3 charger board replacement, and really thought everything went well (and the USB-C port works again!) but now I have a thick vertical green line going through the display. Anyone ideas what the issue could be? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
That is a damage on the screen or a damage on the flex cable of the screen, it can be a visible damage or internal damage caused by pressing or forcing the screen.
这个答案有帮助吗?
得分 1
2条评论:
Thx for the reply. That's what I was afraid of. :-(
完成的
Did you ever resolve the problem? I have the exact same issue.
完成的
添加一条评论
I have encountered this problem as well, and after consulting my friend who works in the phone repair industry I discovered it’s apparent source as well as why it seems common among us. When replacing the charging port one of the screws (the one that is inserted through the small plastic piece covering the charging port) must be inserted with care as the screw is slightly too long. If fully tightened it will actually damage the screen.
If you reopen the phone, you may notice that this line occurs perfectly aligned with the screw in question. I’m not sure if it was intentionally designed this way or not as an anti-repair element but it’s something you should look out for. I’m going to be replacing the screen soon and will update with my findings. I may not even replace the screw as it risks damage to the screen.
Someone might get lucky by loosening the screw, but I fear that usually when this line appears it is irreparable.
这个答案有帮助吗?
得分 1
添加一条评论
I have this issue too, started after I switched the charging port as well… we're you able to fix it?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brian Grant 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 29
总计 1,562
