跳转到主内容
期待已久的MacBook Air更新到来,带来了全新的英特尔酷睿i5处理器、升级了的视网膜显示屏以及众多其他更新。发布于2018年11月7日。
149 个问题 查看全部
Why is my screen suddenly showing issues?
Hi! My macbook’s lcd suddenly malfunctioned. It wasn’t water damaged or anything. I was just working and printing when I came back there was this black spot on the screen.
Then when I got home, it started to flicker.
What could have possibly caused the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Ouch! I’m suspecting some screen cleaner dripped to the bottom of the display wetting the backlight LED strip so one of the LED’s burnt and some got onto the column ribbon cables which connects to the T-CON board held within the uppercase
See if you can use a hair drier to dry it out
If not, you’ll need a new display assembly:
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Johnal Khow 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 53
