跳转到主内容
Portable tablet computer released in July 2017. Has an 8" display , 2GB memory, and 16GB storage. Identified by model number TB-8504F.
17 个问题 查看全部
I broken my tablet screen from the inside
I broken my tablet screen because i was angry.. (with my knee). I feel so bad right now and i dont wanna parents to notice. Is it still fixable? The screen is black with cracks and there are few lines from lock screen. Its new tablet that my parents gave me. Can I fix it by my self? Because i don't know where is repairing shop. If i need to buy something (part etc.) Please tell me what and i will save money for it.
Version is Lenovo M8 aka Lenovo Tab 4 8
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 10
8条评论
@fxrpe ... please give the model number of your device and we can assist you in the right direction.
完成的
Im not sure what is the model, im in trqin now.
Ill tell you later.
完成的
whenever you find your model number, google that along with screen replacement and youll find the part needed to install. then, you can google or youtube how to replace your screen by using the same model number and how to *.
完成的
@jostewcrew I can't find any screen online that I can buy and replace. I can't find either how to replace it. By the way, the model is Lenovo M8 (Lenovo Tab 4 8) .
完成的
I have the same problem but with a surf 7" onn tablet gen 2 with android. please tell me what I can do to fix it.
完成的
显示更多的3条评论
添加一条评论
2个答案
已选择的解决方案
here are two solutions for you for your tb-8504f… the first option is for if you only damaged the top layer of the screen. youll want to tear down the unit ( videos linked) and then test the layer under neath for functionality. if it is damaged, solution 2 will replace both the top and bottom layer of the screen. again, video is linked. good luck.
replacement of digitizer screen only:
https://www.youtube.com/watch?v=eG56FmSP...
https://www.deviceparts.com/screen-repla...
replacement of digitizer and lcd panel:
https://www.youtube.com/watch?v=3k1G0ctz...
https://www.amazon.com/Display-Assembly-...
这个答案有帮助吗?
得分 2
1条评论:
No I need to fix my tablet I accidentally dropped juice on it
完成的
添加一条评论
My M8L Plus tablet screen is busted how do I fix it at home without spending any money
这个答案有帮助吗?
得分 0
2条评论:
Ryaeth, what's the model number of the tablet? I'm afraid there's probably no way to replace a broken screen for free, but depending on exactly which one you have, it could be pretty inexpensive; I saw one model's screen that cost less than $10 USD for a brand new replacement.
完成的
This Lenovo model has what appears to be top and bottom end caps do they need to come off before I can get the digitizer and screen off this screen is destroyed and there's no model number on the sticky tape it's gone it is Dolby sound Linville
完成的
添加一条评论
添加你的答案
Barbora 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 45
过去 30 天: 157
总计 8,580
