跳转到主内容
The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
151 个问题 查看全部
Why is my home button keep moving
I placed the home button back the same way it was, however when I lay the screen down and try to hit it, there’s too much space and it ends up pushing back and or moving . How do I fix the middle button so that it fits properly ?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The old adhesive on the home button bracket can not be re-used. It should be cleaned off very well and replaced with adhesive like Tesa 4695 (PET red double sided tape transparent adhesive equivalent is ok) or 61395.
Additionally with B7000 liquid glue around the bracket edges on both sides with some of it also on the rubber gasket of the home button.
This will require 24-48 hours to fully set and that’ll fit snugly.
这个答案有帮助吗?
得分 2
8条评论:
So I should glue the button in place and use the red tape to secure the black bar down ?
完成的
Yes, be careful where the glue is used should be only on the black rubber gasket portion and around the sides of the home button bracket (black bar).
完成的
I secured the bracket down but it still seems like there is too much space in between the bracket and the home button . And if I can’t glue the home button to the screen how do I fill the space ?
Could I put some red tape on the back of the home button ? Because after all that it still keeps moving due to space
完成的
That may be due to the thickness of the digitiser. If it is depressed too low you can bend the middle of the home button bracket closer to the home button slightly to fix that.
Don't add red tape behind home button that will stop it from clicking. Is the little black dot there on the home button clicker on the orange sticker?
完成的
It’s a new home button due to my other one shattering . So I bought it brand new from ifixit. So I would say yes . I’ll try bending it a little @benjamen50
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Kaylee hahn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 811
