跳转到主内容
Google Pixel 系列第三代中的其中一隻。Pixel 3a為系列中主打中低價位的一員,其中,鏡頭型號與同系列旗艦款式同款。2019年五月發布,有全黑、純白、淡紫三種顏色(前兩者電源鍵為橙色,紫色為黃色)。
41 个问题 查看全部
Phone screen intense bright light until pressed
Recently my phone screen started behaving weird. It would flicker to a bright mode when I touched the screen in a specific spot. Now it is in the bright mode most of the time until I press firmly down on the screen? has something inside the display assembly come loose? Booting into safe mode has not solved the issue, Also tried the factory reset and still not luck. Thinking it is probably a hardware issue now. Attached a video for reference
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Screen module may be loose or going bad. You can fix it yourself if it’s just a little out of place and if you’ve fiddled around with phones before.
Even if you need to get a new one, repair is not all too costly.
Hardest thing is waiting for the spare part to arive, can take from 2 days to a week or more, depending on availability.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tyler Bourque 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 1,069
