跳转到主内容
加入维修社区 - 创建账户
PS4 控制器型号 CUH-ZCT1。这款由索尼电脑娱乐公司于 2013 年 11 月发布的六轴 3.7 V 锂离子电池控制器维修起来并不复杂。(注:拆解指南不适用于此型号)
Controller not reading battery correctly?
I have two controllers, let’s call them Controller A and B.
Controller A is perfectly fine, it charges as normal. Battery A is fully charged.
Controller B shows a yellow light and can turn on when the micro-USB is inserted HOWEVER it immediately turns off as soon as I remove the micro-USB cable.
Today I put Battery B into Controller A and PS4 says the battery is dead. Currently charging the controller and Battery B IS recharging.
However after placing Battery A into Controller B, the Controller stays on for like 2 seconds then turns off. PS4 says Dualshock is disconnected, charge the battery. I’ve placed the Controller on charge but after 5 minutes I removed it and the controller won’t turn on. Just to reiterate Battery A is fully charged.
So what’s the issue with Controller B and how can I fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
I have this issue too, and I regret raging because I'm 99% sure me hitting my controller because of stick drift is the problem. At this point you and me should just buy a new controller. Funny thing is I had this controller for 2 months and in the first week I experienced stick drift. &&^& Sony at this point.
这个答案有帮助吗?
得分 0
1条评论:
Update: Controller completely doesn't charge/turn on anymore. The only thing I can suggest is to replace to motherboard. That might be expensive and you could potentially mess up the controller even more if you don't know what you're doing. Buy a new one just to be safe. That's what I'm going to do.
完成的
添加一条评论
I’m experiencing the same problem. My controller charges the battery but if I disconnect the usb cable, the PS4 says the battery is low and it disconnects.
Did you managed to find a solution? The battery pins on the motherboard are receiving the 4.12V from the battery
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tom Y 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 23
总计 1,694
