跳转到主内容
Lenovo Tablet-7304i. Announced in November, 2017.
Why can't I switch on my tablet?
I tried holding down the power button but my Lenovo Tablet would not turn on. I also tried holding down volume buttons and power buttons together but to no avail. I tried resetting my Tablet, still no use. I’ve tried almost every single way but it still won’t turn on.
However, when my Tablet is charging, I can hear a faint sound coming from the speakers near the camera. When I disconnect the charger from the Tablet and hold down the power button, I still hear the faint sound.
I have no idea how to fix it. If you have any idea on how to fix it, please let me know fast. The tablet isn’t old at all and I did not spend a lot of time using it properly.
Thanks in advance! :-)
Model: Lenovo TB-7304i
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Is it possible that it does turn on ,but the screen doesn't recieve power? Maybe you are just not receiving the feed.
完成的
Maybe, but how could I fix it?
完成的
@aj_clark If you have worked on tablets before, you could open it yourself to check if everything is connected correctly inside.
However, a trip to your local tech might save you some time + eliminate risk.
完成的
@chris_p I might do that, thanks for the help! :-)
完成的
添加一条评论
1个答案
最有帮助的答案
try to plug the charger in maybe is just discharged
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Adam JC 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 383
