跳转到主内容
Dell Precision is a series of mobile and fixed computer workstations designed for professional consumers and CAD/Architecture/CG professionals, or as small-scale business servers.
20 个问题 查看全部
Crack on socket pin of RAM DDR4
Dear Team,
I have one problem need your help.
My laptop is Dell precision 5520, one socket of RAM have carck at the pin No.145. This pin is weak and not good in touch to RAM pin .Laptop usually stop working when has shock.
(Pin No.145: Bank address inputs: Define the bank (with a bank group) to which an ACTIVATE, READ, WRITE, or PRECHARGE command is being applied. Also determine which mode register is to be accessed during a MODE REGISTER SET command)
Please have look attached photo and help me how to fix this issue. I want to hear your advice on this matter.
Here is the link of this RAM datasheet:
https://www.micron.com/-/media/client/gl...
Thanks a lot!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @taile ,
Maybe a bit desperate but have you thought about filling the gap with conductive glue - info only?
这个答案有帮助吗?
得分 1
1条评论:
@jayeff
Thank you for your advice!
This is a good idea. However the gap is very small, i afraid the conductive glue will spread out and make short circuit for RAM and CPU and the pin will stick/fix to plastic, affect to RAM when insert to the socket.
完成的
添加一条评论
添加你的答案
Tai Le 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 107
